googlesta löytyy sitä sun tätä mutta olisiko jollakin sellaista hyvää listaa jonka voisi tulostaa
auto on w164 280cdi -06
paitsi että näitäkin on varmaan varustekohtaisia kaavioita??
									Sulakekarttaa mölliin?
S204 200CDI A -14
ex.
S203 200CDI A -05
S211 320CDI 4Matic -06
W164 280CDI A -06
S204 200CDI A -08
W211 200CDI A -03
W210 200CDI -00
W124 200D -90
						ex.
S203 200CDI A -05
W164 280CDI A -06
S204 200CDI A -08
W211 200CDI A -03
W210 200CDI -00
W124 200D -90
Vastataan tällenkin palstalle välillä tuossa olisi.
Fuse (Amps) Circuit
F20 (5A) Aerial signal amplifier
F21 (5A) Rear AC
F22 (5A) Parking aid, auxiliary heater
F23 (10A) Audio system (rear)
F24 (40A) Supplementary restraint system (SRS)
F25 (15A) Navigation system
F26 (25A) Door function control module, right front
F27 (30A) Seat adjustment, passenger
F28 (30A) Seat adjustment, driver
F29 (40A) Supplementary restraint system (SRS)
F30 (40A) Supplementary restraint system (SRS)
F31 (10A) Steering wheel heater
F32 (15A) Suspension control system
F33 (25A) Keyless entry and start system
F34 (25A) Door function control module, left front
F35 (30A) Audio unit amplifier
F36 (10A) Telematics
F37 (5A) Rear view camera
F38 (10A) Television tuner
F39 (7,5A) Tyre pressure monitoring system
F40 (40A) Tailgate closing aid
F41 (25A) Interior lamps
F42 (25A) Sunroof
F43 (20A) Rear screen wash/wipe system
F44 (20A) Auxiliary power socket (rear)
F45 (20A) Auxiliary power socket (front)
F46 (15A) Cigarette lighter
F47 -
F48 -
F49 (30A) Heated rear window
F50 (10A) Rear screen wash/wipe system
F51 (5A) Charcoal filter switch
F52 (5A) Supplementary restraint system (SRS)
F53 (5A) Suspension control system, fuel pump (FP) (AMG)
F54 (5A) Multifunction control module 1
F55 (7,5A) Instrument panel, headlamp switch
F56 (5A) Data link connector (DLC)
F57 (20A) Fuel pump (FP)
F58 (7,5A) Data link connector (DLC), CAN data bus gateway control module
F59 -
F60 (5A) Data link connector (DLC), engine bay fuse box/relay plate (F58)
F61 (10A) Supplementary restraint system (SRS)
F62 (30A) Seat adjustment, passenger
F63 (30A) Seat adjustment, driver
F64 -
F65 -
F66 -
F67 (25A) AC/heater booster fan
F68 (25A) Heated seats (rear)
F69 -
F70 (15A/20A) Trailer socket
F71 (30A) Trailer socket
F72 (15A) Trailer socket
F100 (30A) Windscreen wash/wipe system
F101 (15A) AC/heater booster fan, engine management
F102 (15A) Engine coolant pump motor (petrol), transmission fluid cooler pump motor (Diesel)
F103 (25A) Engine control module (ECM)
F104 (15A) Engine control module (ECM)
F105 (15A) Engine control module (ECM)
F106 -
F107 (40A) Secondary air injection (AIR) pump
F108 (40A) Suspension compressor pump
F109 (25A) Electronic stability program (ESP)
F110 (10A) Alarm system siren
F111 (30A) Transmission
F112 (7,5A) Headlamps
F113 (15A) Horns
F114 -
F115 (5A) Electronic stability program (ESP)
F116 (7,5A) Transmission
F117 (7,5A) Cruise control distance range control module
F118 (5A) Engine control module (ECM)
F119 -
F120 (10A) Engine control module (ECM)
F121 -
F122 (25A) Engine control module (ECM) (petrol), starter motor (Diesel)
F123 -
F124 -
F125 -
F126 -
Fuse (Amps) Circuit
F4 -
F5 -
F6 (40A) Electronic stability program (ESP)
F7 (100A) Air conditioning (AC)
F8 (150A) Engine bay fuse box/relay plate 1
F78 (150A) Auxiliary heater
F79 (60A) Multifunction control module 2
F80 (60A) Multifunction control module 2
F81 -
F82 (150A) Load area fuse box/relay plate
F83 (5A) Seat occupation control module
F84 (10A) Supplementary restraint system (SRS) control module
F85 (30A) Transmission
F86 (30A) Fascia fuse box/relay plate
F87 (30A) Transfer box control module
F88 (70A) Multifunction control module 1
F89 (70A) Multifunction control module 1
F90 (70A) Multifunction control module 1
F91 (40A) AC/heater blower motor
F10 (10A) AC/heater booster fan
F11 (5A) Instrument panel
F12 (15A) Air conditioning (AC)
F13 (5A) Steering column function control module
F14 (7,5A) Ignition switch, CD changer
F15 (5A) Compass
F16 -
F17 -
F18 -
									Fuse (Amps) Circuit
F21 (5A) Rear AC
F42 (25A) Sunroof
F47 -
F48 -
F59 -
F64 -
F65 -
F66 -
F69 -
F106 -
F113 (15A) Horns
F114 -
F119 -
F121 -
F123 -
F124 -
F125 -
F126 -
Fuse (Amps) Circuit
F4 -
F5 -
F81 -
F15 (5A) Compass
F16 -
F17 -
F18 -
Mitään näistä mersuista ymmärrä, mutta *.rilla on selvitty ja autettu muitakin
Pitää vaan ajaa tolla -97 290td väykyllä kun ei ole varaa uudempaan
